New Projects; EQ's and Mastering Schematics
Postby wlangfor@uoguelph.ca » Thu Feb 21, 2019 3:21 pm
So, when these are done I'll post them in the examples section but they are very close and I thought I would share my work of the last two weeks:
This EQ makes mastering sound a bit like the gear they used for weekend's starboy album:
Download LA School Shelf V0098 (remake).fsm
(188kb)
This Mastering console sounds very much like the mid-career hardware used to master Michael Jackson:
Download LA School - Voxbox - Curello Alternative v0113.fsm
(226kb)
This is a compressor that another member from the forum submitted which I'll make sure to make official and attributed once it is done - There was already a carte blanche, but in the time being:
Download g compressor mod V9.fsm
(97kb)
This is a nice EQ that I based on one by Pall made in 2011 when which I opened was surprised by the small CPU utilization. I'm still optimizing everything; When I am done and have the q-values down pat I will convert all coeffs into linear float scaler driven serialized values rather than actual programming. It's time consuming to do for every sample rate but I will complete it.
Download la bands v20.fsm
(191kb)
Has a smooth feel; Sounds like a TV master - kind of flat; Surreal. Not My favorite sound but it is good all the same. Really good in a subtractive manner for mastering vocals.
EULA ==================================
So, just so everyone's on the same page; These bits of programming use knobs which were inspired by a nice one from freepik.net. They were very generic; But all the same should You wish to use these for commercial purposes I would buy a license or make sure the free license is sufficient, it's only polite. Here's a post with more info:
http://flowstone.co.uk/support/viewtopic.php?f=3&t=14575&sid=a7425a5a5e6229b0efafb2b72e882da8
Re: New Projects; EQ's and Mastering Schematics
Postby wlangfor@uoguelph.ca » Fri Mar 29, 2019 2:36 pm
Here's some stuff made with it (all commercial):
Symphonical: Fisher King
https://www.youtube.com/watch?v=P83YFmIy23o
RAP: Cause We have Love
https://www.youtube.com/watch?v=cVFzYWE6gBs
Used a Sennheiser Mic and a Roland Boss CD bouncer with FL 10 to master. Uses Navigator from My betas as well:
Also, Uses the Final version of LA Bands EQ:
http://dsprobotics.com/support/viewtopic.php?f=3&t=14740
Postby wlangfor@uoguelph.ca » Tue May 21, 2019 4:21 pm
Here's a new version of the shelf EQ:
LA School Shelf V0104 (remake).fsm
beta
(200.04 KiB) Downloaded 355 times
It works a bit better, but I still have the issue with their being a bit of lag when applying the low pass or high pass.
I think for the most part this is due to the wet dry cross fader that like a dezipper removes any crackling noise.
I can try another way of fixing that or maybe I can change the way in which it works. It's a good idea at any rate.
Here's an image showing it in action, press the image to watch a short Youtube video with the same video in a larger form.
EDIT: MMk, so updated this so it has a somewhat smoother display and it also uses 0.2 less CPU. The new schema is uploaded for Your use and research.
Postby lalalandsynth » Tue May 21, 2019 9:29 pm
The Voxbox gui is very confusing , I have literally no idea what does what ?
I think its both a layout issue and just the fact that you did not say what it does :)
Also the fading out Knobs is just tiring , I want the gui to stay still.
lalalandsynth
Postby wlangfor@uoguelph.ca » Wed May 22, 2019 3:20 am
lalalandsynth wrote:The Voxbox gui is very confusing , I have literally no idea what does what ?
When I put all the relevant details in it will be very user friendly. It'll be slick when it's all done.
Postby StereoSpace » Mon Sep 30, 2019 3:40 pm
Hello. Now I am collecting a plug-in master project and I find interesting schemes throughout the forum, but nowhere can I find any controller in which it is possible to double-click to enter numerical values (an example of wave plugins). There is a scheme for such a knob, but I just can’t connect them, apparently my knowledge is not enough. I know there are a lot of responsive people, and can someone help me with a knob?
As soon as I finish the plugin, it will be possible to put the circuit here. But while all the work has stopped due to this knob (
GUI designer
StereoSpace
Postby Spogg » Mon Sep 30, 2019 4:04 pm
This may not be what you had in mind but I offer it anyway.
Data entry systems .fsm
3.06
(69.67 KiB) Downloaded 238 times
Postby wlangfor@uoguelph.ca » Mon Sep 30, 2019 9:06 pm
StereoSpace wrote:Hello. Now I am collecting a plug-in master project and I find interesting schemes throughout the forum, but nowhere can I find any controller in which it is possible to double-click to enter numerical values (an example of wave plugins). There is a scheme for such a knob, but I just can’t connect them, apparently my knowledge is not enough. I know there are a lot of responsive people, and can someone help me with a knob?
Heh, sorry I did not see this post and noticed that Spogg helped out. Good luck stereo space :)
Postby StereoSpace » Tue Oct 01, 2019 10:34 am
Thanks guys for the help! You are unrealistically helping to develop and create! What you do is really cool stuff!
GUI designer
StereoSpace
Postby wlangfor@uoguelph.ca » Tue Oct 01, 2019 1:41 pm
Yeah, flowstone is great, so is open source :D.
