How to fix DSERR_GENERIC and Direct Sound error ?
I've had these errors for a few days and don't know how to fix them. I'm using windows 10.
- error.PNG (5.73 KiB) Viewed 8956 times
- SmartSelect_20210422-083145_Samsung Internet.jpg (32.82 KiB) Viewed 8956 times
- Camil
Re: How to fix DSERR_GENERIC and Direct Sound error ?
Not much information there so here's a generic answer:
Normally this type message means that selected device is locked by (software which uses) ASIO, (WDM/KS) or WASAPI Exclusive Mode driver for audio I/O. Locked device can't be shared with other software (though, there has been some audio interfaces which supports sharing even with ASIO).
- juha_tp
So how I can check what software blocking Flowstone because my drivers are up to date.
- Camil
It means that FlowStone wants to use your microphone but windows 10 doesnt allow it. In the windows 10 settings enable the apps to use your microphone, and perhaps it will work
- adamszabo
adamszabo wrote:It means that FlowStone wants to use your microphone but windows 10 doesnt allow it. In the windows 10 settings enable the apps to use your microphone, and perhaps it will work
Thank you very much I had microphone access disabled in the microphone options. I turned it on and the error disappears.
- Camil
Users browsing this forum: No registered users and 92 guests
