Version 1.1.0
1 post
Version 1.1.0
This release introduces the new FlowBoard component for interfacing to our FlowBoard DAQ device. There's also some fixes, enhancements and new components and modules.
Details of all changes:
- New: option to exit exported exes on ESC key press
- New: functions for the Code component, pow, exp, abs, sign
- Fix: search was not identifying matching words in module help text which had capitals in them
- Fix: the ASIO driver now resets automatically after changes are made in the ASIO settings
- New: option to run in background for the Shell Execute component (the default is now to wait for completion)
- Fix: there were issues with single sample delays which resulted in the delay being off by one sample under certain conditions
- Fix: the Signal Analyser wasn't setting the type sometimes on re-load
- Fix: when zooming fully out using the mouse wheel the zoom level was getting stuck preventing you from zooming back out
- Fix: the Bool to True and Bool to False components were not setting state until after sending the trigger out which causing problems when used in feedback loops
- New: sample rate for Direct Sound is no longer fixed at 44100
- Fix: when deleting a module containing either Direct Sound Out or ASIO In/Out the toolbox was not being updated to allow you to add a new one
- Fix: ASIO now updates as you change settings where before you would have needed to turn it off and back on again
- Fix: there was an issue with the compression when saving very small schematics that caused the file to be unreadable
- New: the MIDI to Voices now defaults to starting a new voice for each note
- New: the 'Using Samples' input to the MIDI to Voices has been renamed and allows you to select between reusing the same voice for the same note or starting a new one (default)
- New: option on the MIDI to Voices to specify whether repeating the same note creates new voices or just has one instance when MIDI Sustain is on
- Fix: problem with not sending the complete sequence of stages when a note passes from on to off in the same audio frame
- New: updated MIDI to Poly module to reflect changes made to the primitives
- Fix: there was a missing link in the PWM module
New Primitives:
- FlowBoard
- MIDI to Multi Voice
- SFZ Parser
- Open ASIO Settings
- Hex To String
- String To Hex
- Colour to HSV
- HSV to Colour
New Modules:
- Display Window
- Audio Menu
- Multi Sample
- Multi Sample Advanced
New Primitives:
- FlowBoard
- SFZ Parser
- Hex To String
- String To Hex
- Colour to HSV
- HSV to Colour
New Modules:
- Display Window
- Audio Menu
- Multi Sample
admin - Site Admin
1 post
