Page 1 of 7
Synth: X11
PostPosted: Sun Mar 31, 2013 11:24 am
by billv
X11 has been Updated
Download FSM..
https://web1.storegate.com/share/MvVwhV1
Download OSM (SM)
https://web1.storegate.com/share/sd8FcnP
64 Bit VST2 Plug in
https://web1.storegate.com/share/4byKC7E
See all Updates in one blog...
http://bvmusic.blogspot.com.au/
Re: New Synth: X11
PostPosted: Sun Mar 31, 2013 11:28 am
by billv
The X11 has been updated to 2.0
NEW FEATURES:
* New timing systems.
* Clock locked to VST Time, the rest gets Tempo time
* New Arp
* 7 ways to generate notes
* New Ticker send option to control Arp sequences
* New value display when moving tickers
CASUALTIES:
* X Box Module
* Advanced timing options
GENERAL REPORT:
I thought i would have to build a whole new system, but in the end i cheated, and just dropped the
FS timing systems in, and fixed the subsequent issues. Its not real pretty in the FSM, but this release
was just about getting the "timing platform" right. I know I should re-build/re-design the whole thing.
But that's another day.
As usual, please report any bugs.
Re: New Synth: X11
PostPosted: Tue Apr 02, 2013 11:52 am
by jjs
Very nice!
Great job.
Re: New Synth: X11
PostPosted: Tue Apr 02, 2013 2:17 pm
by tester
1 million primitives, and still working! ;-)
Good to know, and nice work by the way.
Re: New Synth: X11
PostPosted: Sat Apr 06, 2013 2:12 pm
by Perfect Human Interface
Holy crap this is scary.
Re: New Synth: X11
PostPosted: Sun Apr 07, 2013 2:51 am
by billv
jjs wrote:Very nice!
Great job
Thanks. It's going alright so far. My notepad has about 6 issues/bugs already. Most are minor.
tester wrote:1 million primitives, and still working
This update is just the "timing fix". The whole thing going to have to be re-built.
I've built another 3 new seq systems already....next update will be huge...but will be a long way
off cause I want to keep experimenting/learning ruby.
So i hope to avoid the constant updating like last year. 1 or 2 updates a year should be fine.
(Hopefully the 2.0 update can stand on it's own for a few months)
Perfect Human Interface wrote:Holy crap this is scary.
Yes it is. if your new to it, the general advice is "Disable" the matrix trigger System, select
"User" mode in the Seq and play it like a normal synth. One hand one your keys, the other using
mouse to tweak and learn what's going on.
The Trigger System takes the Synth somewhere else, so it might help to think of the X11, as two
synths in one. When this trigger system is on, the X11 is basicly a "Clock", with options for synthsis
attached. The Trigger System is also a "Compositional" tool. It's a de-facto automation system.
It turns the X11 almost into a D.A.W. I like to think of it as a band, where the matrix triggers are
the players(instruments), and the the actual triggers tell them when to play or the shut up :D .
The "Random all trigger" button is a "songwriter", creating a new musical piece in one hit.
so yeah, when it's all too much, work via "subtraction". Try simple stuff. A few triggers at a time.
Best way is of course, load X11 (VST) into your current song, copy/paste a riff from your song to the
X11. Run the host, sit back and listen to what happens to your song, ha ha ha ha ha :lol: :lol: :lol: .
Re: New Synth: X11
PostPosted: Mon May 13, 2013 8:48 am
by billv
X11 2.0 BUG REPORT
The EQ MOD, can cause the synth to crash.
Please ensure it is TURNED OFF in TWO Places.......
In the matrix section,
and in the EQ Mod itself.
It has been removed from the 2.01 Update, soon to be released.
Re: New Synth: X11
PostPosted: Fri May 24, 2013 11:16 am
by billv
X11 has been Updated to 2.01
New Stuff
* 4 Note Seq, 10 save/load slots, with 2 options for automation
* Amp Envelope Matrix trigger
* User controls to set both preset Amp Envelopes
* New Wave OSC, 10 Waves, with 2 options for automation
* Ticker Section fully Rebuilt, each ticker now has 32 sends available
* New Mod Rate controls in Reverb,Chorus and flanger
* New Mixer
* Seq Select is now available via Ticker send
* Cutoff is now available via Ticker send
Casulalties....
* Eq Mod
* Display window
* Tutorial window
* Ear Trainer
* Data window
* Arp seq
* User Arp Seq
* Drone Seq
Download via first post...
Re: New Synth: X11
PostPosted: Sun May 26, 2013 9:57 am
by billv
Another dud update....will be another very soon......
More heavy casualties........
Wave Seq gone
Draw seq gone
Wave mod(display window) gone
Fishtank gone
Anything causing a midi timing error is being removed.
probably end up with an empty schematic......
Re: New Synth: X11
PostPosted: Sun May 26, 2013 12:04 pm
by tester
:mrgreen:
Are you sure you wish to end up like this?
