record your hardware synth...
1 post
Hi
ever wanted to record your hardware synth,but when busy you missed a patch, or your knob of your synth does not react so good anymore, well i had.
And therefore i made a very simple program, it is called:
Easy Midi Synth Recording Help Tool
So now you turn your wave recording software on and use EMSRHT to get every patch of your synth.
you can switch banks and patches and hit middle C
you can also set the lenght of how long the key has to be pressed, in case of pads and sweeps
then when you're ready recording you can start the hard and lonely job of cutting all samples, make perfect loops, and naming them pffffffffffffffff.
remember it is just a first version, so bugs can happen.
ideas for next are, automatich bank and patch switching and automatic every key of a few octaves.
maybe it is useable for some, have fun.
- JJS-EMSRHT V1-00.zip
- Easy Midi Synth Recording Help Tool
- (1.99 MiB) Downloaded 1215 times
jjs - Posts: 142
1 post
