Latest update for Martin's 'Randy' synth
Re: Latest update for Martin's 'Randy' synth
Postby trogluddite » Sat Jun 15, 2019 8:36 pm
k brown wrote:but not being very 'norm' myself
If you do see any "normal" people showing up on the forums, you should immediately report this to a moderator - we can't be having that kind of behaviour going on around here! :lol:
Postby Julian Ray » Mon Jul 01, 2019 6:42 pm
This synth sounds so good!
I was playing with Randy+ yesterday, creating some presets and really felt the need to modulate Noise with ADSR (or even better to have it's own ADSR for Noise section).
Maybe it's already implemented and I'm using older version?
Cheers,
JR
Julian Ray
Postby k brown » Tue Jul 02, 2019 2:41 am
I initially tried to make the Filter env available in the Mod bank, but the EGs are custom-coded jobs by Martin and it didn't play well with the other kids in the sandbox. :( (I probably just don't know enough about packing/unpacking).
Maybe someone else can have a go - one thought I had was to link the Filter EGs' sliders to a hidden, separate 'normal' ADSR just for mod purposes; I just didn't want to clutter the GUI with a dedicated mod EG.
Plug-ins can be downloaded here:
https://cp.sync.com/files/355278247
Postby Julian Ray » Tue Jul 02, 2019 12:15 pm
Thank you Kevin - good point!
It just feels like this synth could benefit from noise's filter/amplitude modulation.
Cheers!
Julian Ray
Postby martinvicanek » Tue Jul 02, 2019 9:30 pm
I see what you mean. The DSP part is easy, however the GUI would get all messed up.
Postby Julian Ray » Tue Jul 02, 2019 10:10 pm
martinvicanek wrote:I see what you mean. The DSP part is easy, however the GUI would get all messed up.
Hi Martin,
Yes, I understand - GUI is pretty compact... There is some place in the MIDI section though.
Julian Ray
Postby k brown » Wed Jul 03, 2019 1:10 am
An idea I had was to have 1/2-mini knobs below the Mod Bank, for a mod EG; and just extend the bottom of the GUI a bit.
Postby martinvicanek » Wed Jul 03, 2019 7:52 am
Here is a version with noise envelope. Thank you Julian for suggesting this.
Edit: fixed Tilt filter normalization.
Randy.fsm
(291.97 KiB) Downloaded 120 times
Postby Julian Ray » Wed Jul 03, 2019 11:24 am
Great! Thank you Martin :D
Julian Ray
Postby k brown » Wed Jul 03, 2019 12:33 pm
Very cool, Martin - I incorporated this into to the most recent update rather than the earlier one you used.
I also added a button to bypass the Noise EG for operation as in the original, and another to bypass the Noise Comb Filter. Now calling this v1.02 (with revised Spectral Tilt Filter).
Randy_v1.02.fsm
(325.45 KiB) Downloaded 74 times
Randy v1.01.jpg (157.71 KiB) Viewed 2925 times
