Line Editor
Re: Line Editor
Postby Father » Wed Nov 12, 2014 9:37 pm
TheOm wrote:It works like it should here. It loads the correct state even if the editor hasn't been opened. I can only test for Fuity exports though.
Confirmed. FL version works fine. :!:
So whats the cause?
Father
Re: Line Editor
Postby nix » Thu Nov 13, 2014 9:49 am
can an 'after load' trigger be introduced somewhere to mitigate?
nix
Re: Line Editor
Postby Father » Tue Nov 18, 2014 4:01 pm
nix wrote:can an 'after load' trigger be introduced somewhere to mitigate?
That after load wasn't always working. I think it had something to do with ruby initializing before receiving the input data, seems to be fixed in the 3.0.6 update.
Father
Re: Line Editor
Postby Antimac » Fri Nov 21, 2014 9:47 pm
Many thanks for sharing this TheOm! This is truly awesome!
Antimac
Re: Line Editor
Postby Father » Sun Dec 21, 2014 8:31 pm
I'm not sure but it seems to be working in 3.0.6 version.
Father
Re: Line Editor
Postby TheOm » Mon Dec 22, 2014 2:29 am
Father wrote:I'm not sure but it seems to be working in 3.0.6 version.
Nope, it loads a wrong state sometimes but I just can't figure out how to fix it.
TheOm
Re: Line Editor
Postby Perfect Human Interface » Mon Dec 22, 2014 3:28 am
This in an unhelpful post but Ruby seems to be prone to screwing things up on load in general. I recently had to remove all instances of a ruby block (it was one short line with an input and an output) from a schematic and replace it with green because the schematic wouldn't load saved values correctly with it.
Re: Line Editor
Postby tulamide » Tue Dec 23, 2014 1:42 am
Since the ruby edit instance uses "def event", it probably won't be solved with 3.0.7, so here's a proposal. Maybe it helps, if you forego ruby values and sending them. Instead you could use global variables. That doesn't solve the problem of the order (declarations first, best done on top layer as first inserted object), but you can at least eliminate the ruby value construct as a possible source of issues.
Edit: Made a quick schematic of what I mean.
RubyValue_Replacement.fsm
(464 Bytes) Downloaded 471 times
Re: Line Editor
Postby MyCo » Sat Jan 10, 2015 8:09 am
OK, I don't fully understand the code... But:
    1. never EVER call getViewSize in init, as it is called before views are initialized
    2. When you have a calculation for graphic stuff, call it from draw. When you want to force a recalculation, set a status value to nil and call "redraw". This'll call draw and implicitly force a recalculation (that has to check the status value and only execute when nil, set the status value to something when it's done)
    3. never rely on input values (and their type). There is an issue at the moment (probably not worth fixing, cause it would mess up existing code).
regarding point 3:
This is a quite important one. It causes a lot of ruby exceptions on first load. Connectors might startup unitialized. When you have an input "foobar", make sure it get's checked first before you do something with it. eg:
return unless @foobar.is_a?(...)
or a bit more unsafe:
return if @foobar.is_nil?
or assign it to an internal value with a forced default. eg. for a Numeric:
@myFoobar = @foobar||0
My 2 cents... @Father, hope that helps :twisted:
MyCo
Re: Line Editor
Postby Father » Sat May 30, 2015 10:26 pm
Thanks MyCo.
I used static values instead of calling getViewSize not only in int, but the whole code, it wasn't the case. I think it draws before receiving the preset array. Because adding a delayed after load trigger, sometimes makes it work. like this:
of course this is not a solution, it fails with different schematics. Is there a way to make sure the input data is received before first initialization of the ruby code? or something like that...
Father
PreviousNext
cron
