Line Editor
Re: Line Editor
Postby MyCo » Sat May 30, 2015 11:13 pm
This looks like a bad hack to me. There are probably a lot more reliable ways. Not sure what your exact problem is, this thread is really old now.
Is there a way to make sure the input data is received before first initialization of the ruby code?
No, and I don't even think that this is what you want. As I mentioned before: calculate when needed! I don't see any need for calculation on initialization...
MyCo
Re: Line Editor
Postby Father » Sun May 31, 2015 1:26 am
MyCo wrote:No, and I don't even think that this is what you want. As I mentioned before: calculate when needed! I don't see any need for calculation on initialization...
You were right specially about doing stuff on the Int.
The line editor might get fixed after all... ;)
Father
Re: Line Editor
Postby StereoSpace » Wed Jun 03, 2015 2:52 pm
a very useful thing! but how to change the size?
GUI designer
StereoSpace
Re: Line Editor
Postby Wassaka » Sat Aug 13, 2016 2:59 pm
Hi! I am trying to resize this line editor but I don't found any reference to size in te code... I am newbie in ruby, please help!
Wassaka
Re: Line Editor
Postby TheOm » Sat Aug 13, 2016 5:25 pm
You don't have to change the code.
To resize, go inside the module and change the size of both the editor and the load/save bar, then reposition the load/save bar in the outer module and resize the outer module to fit.
When you're finished double click inside the editor to reset it.
TheOm
Re: Line Editor
Postby Wassaka » Sat Aug 13, 2016 5:44 pm
TheOm wrote:You don't have to change the code.
Thanks a lot!!! And very usefull tool! :D
Wassaka
Re: Line Editor
Postby lalalandsynth » Wed Jul 12, 2017 12:24 am
Old post i know , but having problems with this.
When I use this as implemented by Father in the advanced envelope it accumulates in memory...forever.
Any thoughts ?
lalalandsynth
Re: Line Editor
Postby TheOm » Wed Jul 12, 2017 1:39 pm
I've seen your posts and have tried to look what could be causing it.
However I can not see any extreme increase in memory like you reported here http://dsprobotics.com/support/viewtopic.php?f=2&t=8232&p=33433
TheOm
Re: Line Editor
Postby lalalandsynth » Wed Jul 12, 2017 3:36 pm
Yes, that is an extreme example but just using the barebones Advanced envelope found here ..
viewtopic.php?f=3&t=3388&start=0&hilit=advanced+envelope
- will cause a memory leak for me.I thought it was a 3.09 issue , so i opened in 3.08 ,exported as vst and it has the memory leak , it is much, much slower then reported in my full plugin but its there , just try leaving it running for 20 min or so .
Or just watch it accumulate a few K as it runs .
Here it is.
Advanced Envelope.fsm
(496.6 KiB) Downloaded 311 times
lalalandsynth
Re: Line Editor
Postby lalalandsynth » Wed Jul 12, 2017 8:33 pm
I tested this again for demonstration purposes.
Advanced envelope - exported as VST from 3.08.
I took 3 screenshots over a half hour or so.
Opened. 18:40 / 22.180 K
Advanced envelope open.jpg (83.17 KiB) Viewed 14593 times
Later 19:06 / 39.304 K
Advanced envelope 1.jpg (81.88 KiB) Viewed 14593 times
Later 19:23 / 49.304 K
Advanced envelope open2.jpg (77.8 KiB) Viewed 14593 times
lalalandsynth
PreviousNext
