Hello!
I decided I wasn't finished,
edit-it certainly didn't follow notes in MIDI trig lock mode for such a long time as I had put in this line,
although if you use bend mode, it tracked pretty surely
Download is in the first post.
Now it uses a Chebyshev LP instead of a band-pass->
[img width=771 height=600]http://imagizer.imageshack.us/v2/xq90/922/ez8aVh.png[/img]The performance is ever so sweet, please try it again- and I would love feedback(pun noted)
Instructions:-
- Set gain first. 0db pre amp is multiplier x1. This is where my Audiobox sits. Echo Layla at consumer setting is x3. The fine is adjusted with the knob.
- Fine tune gate pots. This is the note on/off gate for each string.
- If you'd like to use velocity, now press Velocity switch. The edit boxes set min and max, and the pots on the string groups adjust upwards in velocity.
The figure sums the floor(min) value, so for more stable values, put min up and lower the pot(s). Velocity function works fine now in this build.
- Save a preset or project with your set up roughly in order and enjoy playing!
Other notes-
Mono: forces polyphonic playing into mono MIDI. This can still use more than one MIDI channel if you have set that in the string groups.
Bend: will bend strings in tone steps. It will sound terrible on plucks, but tones with consistent sustain sound and play real nice.
My 2SYN MIDI is for:-
Noodling and preset surfing
Composing
Scoring(bend mode off)
Live Performance
This project means a great deal to me, I have not written any programs that are so novel and rewarding.
Please feel free to alter and distribute it. If you would like to host it on your fileshare, I would appreciate it.
I want this binary to outlive me.
Stay tuned in!-- Nick(Phonics)
ps
-the unit is now samplerate independent, so try it at 96k if like
-Also I have a hack in the bend mode I need to fix. This means that it can hang a MIDI note once every 5 minutes or so.
If this happens, press Clear
