RDGAudio's Speaker Vibrator VST in Flowstone
• Page 2 of 3 • 1, 2, 3
Re: RDGAudio's Speaker Vibrator VST in Flowstone
Spogg wrote:I'm sure that you being a Photoshop expert helped!
He is a Photoshop expert himself
His PS plugins are well known in the scene as well
With ballistics.
- vibratingSpeakers2.fsm
- (223.05 KiB) Downloaded 1216 times
- Lex248
djcrazyvdj wrote:Really good work martinvicanek. But how can I make my own speaker design with it? When I am adding my Image from Bitmap loader everything is shaking.
The level meter with your image. It is based on the "Meter - Positive" module from the FlowStone. It can be made in decibels.
- Level_Meter.fsm
- (16.01 KiB) Downloaded 1282 times
- Lex248
Thank you lex. That's what I was looking for.
DJ Crazy
djcrazyvdj - Posts: 25
Good. Here the level meter in decibels with FlowStone image.
- Level_Meter_dB.fsm
- (13.47 KiB) Downloaded 1216 times
- Lex248
Hello Lex. I have been inspired by your Level Meter db.FSM project. I have tried to make a Level Meter from KnobMan Image Strip. But unfortunately nothing is happening. I have exported an Image strip from knobman and have attached that image inside the RAR. Would you mind to check what I am doing wrong?
- dB Meter Not working with custom Image.rar
- (19.17 KiB) Downloaded 1202 times
DJ Crazy
The FlowStone meter won't work with this image. Here it is necessary to take image section.
- Level_Meter_dB_2_2.fsm
- (18.12 KiB) Downloaded 1216 times
- Lex248
