Tools that help me outside flowstone
Re: Tools that help me outside flowstone
Postby wlangfor@uoguelph.ca » Thu May 02, 2019 3:01 pm
OK, big news. I found a free screen recording software called OBS.
It uses only a tenth of the memory that NCH Debut does. The only snag is that it does not select plugin only windows like NCH does. But arguably it can select all of a daw's window perfectly.
So nice, so happy with OBS. :D
https://obsproject.com/
Download VST: LA Bands 15 Band EQ
My Website http://www.leattol.com
Postby Spogg » Thu May 02, 2019 4:12 pm
I paid for NCH Debut and it was OK. Until I found OBS which, for me, is brilliant!
Postby wlangfor@uoguelph.ca » Mon May 27, 2019 2:26 pm
Yeah, well for those people who have problems with the product, give the 32 bit version a try. It solved any issue I'd had.
Spogg wrote:I paid for NCH Debut and it was OK. Until I found OBS which, for me, is brilliant!
wlangfor@uoguelph.ca wrote:OK, big news. I found a free screen recording software called OBS.
Postby JeremyexiCa » Sat Jun 01, 2019 8:34 am
HI there
That exactly what i am looking for.I am looking for a free pdf processing tool which supports to create or convert PDF files directly.My previous tool is a little bit expensive for me.These tools should be possible to work with my windows 8 setup.Thanks for any suggestions.
ознакомился с как выиграть в игровой автомат резидент
стоящие своего играть принцесса острова
JeremyexiCa
Postby Phil Thalasso » Sat Jun 01, 2019 9:20 am
Hi!
If you just want to convert word to pdf, try foxit. The result, however, will look like word.
Should you look for something more of a layout-program, give Scribus a try. In order for that to work, you would need
afpl ghostscript installed on your machine.
Best Regards
Phil
https://www.chip.de/downloads/AFPL-Ghos ... 12016.html
https://www.chip.de/downloads/Scribus-3 ... 10379.html
Phil Thalasso
Previous
Return to Off Topic
cron
