Version 2.0.1
Posted: Mon Feb 06, 2012 7:03 pm
by admin
This release contains many important fixes as well a number of enhancements and extra little features. On top of that we have included our new Vintage Modules pack. This is a collection of 8 user interface elements that you can use in your own projects. All the modules make full use of the Ruby Component introduced in version 2. Just search for 'vintage' in the toolbox.
Change Summary:
- New Vintage module pack
- Fixed some crashing that could occur when loading and saving files
- Fixed a potential crash situation if closing a file while events were still being processed
- Fixed exported exes so they now support all the cursors that are useable from inside the Ruby component
- Fixed a problem which could occur when loading old files with the networking components in them
- Changed the key combo for deleting modules from the toolbox to SHIFT + DEL
- Added the ability for the HTTP Post component to read data sent back from the server
- Added the ability for the HTTP Post to use a port other than port 80
- Fixed the networking components which were not working in version 2.0
- Fixed the exe launch folder so that it is now setup correctly inside Ruby
- Fixed the Load Text component so it no longer produces spurious characters in loaded files
- Fixed a problem with the Ruby component which could cause it to be halted unnecessarily if the system became too busy
- Fixed a potential crash when connecting Ruby components together
- Closed a memory leak that could occur when drawing in Ruby using pens
- Closed a memory leak when using a PathGradientBrush inside a Ruby component
- Fixed a crash when trying to create a Color object in Ruby using nil inputs
- Added a drawBitMapSection method to Ruby
- Added an isKeyPressed method to Ruby
- Fixed the SetBrush method of Pen in Ruby so it now scales the brush correctly
- Added support for the new Phidgets Text LCD Adapter board
- Fixed all the Phidget components so that they have the connection string input from version 1
- Added a new Zero input to Phidget Stepper Controller component so that the value can be reser
- Fixed a problem where using Rotate and Translate components before a Ruby component was resulting in incorrect transforms
- Added the ability to set the transparency for bitmaps drawn using Ruby
- Added a new output to the COM Port component which provides a list of available COM port numbers for the host PC
