Need help choosing skin (Black & White)
Postby djbrynte » Fri Feb 07, 2014 3:02 pm
djbrynte
Re: Need help choosing skin (Black & White)
Postby Xtinct » Fri Feb 07, 2014 3:32 pm
Why not have colour as a user option
Xtinct
Postby djbrynte » Fri Feb 07, 2014 3:36 pm
Because it will be pretty much work and alot to change. I mean like will be huge work and bigger size on synth.
djbrynte
Postby kortezzzz » Fri Feb 07, 2014 7:11 pm
I design my own synths and I dont think its that much to change. you can attach both skins, connect them to a simple selector with 2 radio knobs that will switch between the two and connect the selector to the gui primitive with a redraw. thats it. very simple. if you need a schematic of this approach, i'll post it.
by the way, they are both looks great (as i said in the other post) but i think you should make a nice frame around
the whole synth that will give it a smoother look. if you like the idea, i can help with that to.
kortezzzz
Postby djbrynte » Fri Feb 07, 2014 8:21 pm
Sure you can help me if you want to.
djbrynte
Postby kortezzzz » Fri Feb 07, 2014 10:44 pm
Here is a little schematic that shows how to add into your synth 2 skins (and you can add as many as you want).
hope its helps. i will edit your skin tomorrow and will send it to you. 8-)
kortezzzz
cron
