HTTP post return adding 0 at the end.
I don't know why, i'm getting wrong values return in flowstone.
The error is flowstone add a 0 at the end of the returned string.
I'm still investigating but the php script (i checked it) doesn't give this 0 at the end while the returned http-post string yes!
Anyone had the same issue?
PS i checked once more.
Flowstone add a 0 at the end of the numeric string WTF.
PM me if you are interested.
CoreStylerz - Posts: 327
Re: HTTP post return adding 0 at the end.
Hey CS I have had the same problem. No matter what I do FS always adds the 0 at the end of returned string. I simply made a Ruby to remove it. . . havent found any other solution. I think its a problem within the HTTP prim itself...
- Drnkhobo
Drnkhobo wrote:Hey CS I have had the same problem. No matter what I do FS always adds the 0 at the end of returned string. I simply made a Ruby to remove it. . . havent found any other solution. I think its a problem within the HTTP prim itself...
The problem is that sometimes doesn't happen! That it's bad because you can't return correct values from php to be always stable..
Hey support can you give us some info? a fix or maybe a workaround?
If i undestand WHEN it add this 0 will be cool
Text encoding issues? Maybe the server returns something else then ASCII.
Or the char[] gets messed up? (Since "\0" marks the end of a c string)
HTTP POST example with Client Primitive
Not tested, but should work ...
use this ruby code with Client Primitive.
# TRONIC - HTTP POST EXAMPLE - use it with Client Primitive
# see HTTP protocol for more info
header = "POST /your-url-where-post HTTP/1.1\r\n"
header+= "User-Agent: FLOWSTONERS DEVELOPER\r\n"
header+= "From: user@server.mail\r\n" # optional
header+= "Content-Type: application/x-www-form-urlencoded; charset=us-ascii\r\n"
header+= "Content-Length: #{@body.size}\r\n" # set size accordly to lenght of body text
header+= "Accept: text/plain\r\n" # or other Type
header+= "Accept-Charset: us-ascii\r\n"
header+= "Accept-Language: en-us\r\n"
header+= "Connection: Keep-Alive\r\n"
header+= "\r\n" # end header
# body is url encoded
# Example: parameter=value&also=another
@body = "MACHINEID=123456789&EMAIL=user@server.mail"
request = header + @body
request_as_txt = request
request_as_hex = request.unpack('H*')
output 0, request_as_txt # use as txt Type in Client Primitive
output 1, request_as_hex # use as hex Type in Client Primitive
- Tronic
Encoding a string to base64 will solve this? (decoding then in flowstone)
depends on how you structured your php code when you create your data before convert it to EncodedBase64.
- Tronic
working well encoding data with base64.
