Assembler code improvements campaign
Postby Exo » Tue Oct 21, 2014 9:02 pm
Assembler is great for writing fast DSP code it can do many things that DSP code cannot and enables some great optimizations.
I think if we can get the devs to implement some more opcodes and improvements then the Assembler component can reach its full potential. And with the ability to Write our own functions then we would be on to a real winner.
These improvements will keep us audio/DSP geeks happy and if we get the ability to write our functions for DSP code then we can also extend its abilities for the community.
Here I want to focus on extending the Assembler component with more opcodes. Writing functions is a major wish of mine but it will obviously require a lot more work than adding more opcodes.
So far the wanted/needed opcodes are......
PSRLD xmm1, xmm2/m128
Shift doublewords in xmm1 right by amount specified in xmm2/m128 while shifting in 0s.
(Would be handy for some IEE 754 trickey in log and exp approximations)
PMULUDQ xmm1, xmm2/m128
Multiply packed unsigned doubleword integers in xmm1 by packed unsigned doubleword integers in xmm2/m128, and store the quadword results in xmm1.
(Useful for linear congrugential random number generator)
PADDD xmm1, xmm2
Add packed doubleword integers from xmm2/m128 and xmm1.
(Current implementation only supports PADDD xmm1, m128)
SUB reg,reg/var32
Subract integer
PSUBD xmm0,xmm1/m128
Subtract packed integers
Other fixes improvements...
The long standing ANDNPS syntax colouring bug (all code goes black after this opcode but it works)
Please post any opcodes or improvements you would like to see implemented. Only for Assembler though we can focus on DSP code later in another thread ;)
Exo
Re: Assembler code improvements campaign
Postby KG_is_back » Wed Oct 22, 2014 6:23 pm
maybe also unconditional jump ( jmp; ) would be cool. Not that we can't live without it (there is a simple workaround to mimic it) but it's really a basic opcode, I think.
KG_is_back
Postby KG_is_back » Tue Dec 23, 2014 5:19 pm
:( still no luck... No new opcodes, no coloring bugfixes... In fact I think I have found a new one. "sub reg,reg;" is colored as valid opcode, yet it doesn't work.
KG_is_back
Postby Exo » Tue Dec 23, 2014 6:04 pm
KG_is_back wrote::( still no luck... No new opcodes, no coloring bugfixes... In fact I think I have found a new one. "sub reg,reg;" is colored as valid opcode, yet it doesn't work.
Yes I forgot to remind him about this, and wasn't expecting another release before Christmas.
Exo
Postby MyCo » Tue Dec 23, 2014 7:02 pm
add
cvttps2dq
to the list. It's like cvtps2dq but truncates only
MyCo
Postby martinvicanek » Fri Apr 24, 2015 10:56 pm
Version 3.0.8 SKYLARK
LIST OF NEW OPCODES
psrld xmm, xmm / xmm, var
pmuludq xmm, xmm / xmm, var
paddd xmm, xmm
sub reg, reg / reg, var
psubd xmm, xmm / xmm, var
jmp label / int
mulpd xmm, xmm / xmm, var
xorps xmm, xmm / xmm, var
andnps xmm, xmm
movd xmm, reg / xmm, var / var, xmm
movss xmm, var / var, xmm / xmm, xmm
cvttps2dq xmm, xmm / xmm, var
You can also now use ebx, ecx and edx in the following opcodes:
add reg, reg
add reg, var
sub reg, reg
:D
Postby KG_is_back » Fri Apr 24, 2015 11:38 pm
I'm already giving it a test. It simplifies some structures significantly (and even makes some possible).
KG_is_back
Postby martinvicanek » Sat Apr 25, 2015 7:59 am
I am having trouble with psrld. Please could somebody post a working example?
Postby MyCo » Sat Apr 25, 2015 8:25 am
yeah, seems like it's not working. Its opcode is:
66 0F D2
whitch would mean:
I guess it should be more like the pslld version anyway (with a constant, rather than a register / variable)
MyCo
cron
